An optic module of a particular type which is not compatible with the types of ports on this platform has been inserted into a port. The optic module can not and will not work in the specified port.
Remove the incompatible optic from the port and replace it with one that is supported in that port.
Warning
The %optic% optic module is not compatible with the %portType% ports on this platform - please remove it from port %slotPort%.
| Name | Type |
| optic | String |
| slotPort | SlotPort |
| portType | String |
